TomG2
Jan 15, 2021Explorer
Making Oil
I see on another forum where owners report of showing more oil on their dipstick at the end of a long hard drive than at the beginning. Mostly with turbocharged engines. Anything to this or explanation?
2oldman wrote:NRALIFR wrote:That's what I have, and this truck does not go grocery shopping.
That’s a very common problem on Diesel engines that were manufactured from about 2007-2010. They typically had diesel particulate filters (DPF), but did not use diesel exhaust fluid (DEF).
NRALIFR wrote:Yes, 2008 Cummins 8.3L. I don't think my regen is working properly. Next shop visit when spring returns. It's very tempting to want to delete this thing, but... oh well
You have a Freightliner, right? Maxxforce powered?
NRALIFR wrote:It is. I'm not sure if the shop where I had it replaced could do that or if it actually needed to be replaced. I seem to remember they said it was a goner.. and at only 100k miles. Anyway, it was expensive.
Do you know if the DPF on yours is designed to be taken off and cleaned?
wilber1 wrote:
What vehicle? What engine.
dodge guy wrote:
If you are talking gas motors like the eco boost. They run hot and the oil can and will expand appearing over full. This is why it's best tomch ck it in the morning before you start it. This goes for any motor.
