snowninja's avatar
snowninja
Explorer II
Oct 20, 2013
marker lights
all of the marker lights on my camper have a cracked lens, the light fixture fits in from the back with a rubber 1/4 turn grommet and the housing is sealed. when i picked up replacements fixtures from the RV store it had a foam gasket and looked like a direct replacement of the factory lights. the foam gasket fits between the camper sidewall and the back of the light frame and there is a hole in it feed the wire/lightbulb fixture thru.
do i need to add any sealant around the outside of the frame of the light after i replace it or is the rubber gasket good enough to keep water out?
here is the light in question: light
here is the gasket that comes with it: gasket
  • I had to rebuild my cabover due to a leaking marker light on the front
  • I will be replacing the whole nose underpayment ( aluminum frame ) , on my camper this winter because of marker lights. Take care to seal everyone well.
  • thanks guys i do have some dicor and proseal so for added protection i could add a bead around the frame. the current ones don't have anything except the gasket, once i get them off an inspect will see if any of them have leaked. the gasket is thicker than it looks in the picture..
  • I sealed all of mine with dicor. Not risking leaks, and if I need to open it back up it will only take seconds with a x-acto knife to make the needed cut.
  • I replaced one of mine with and LED. The lights are similar to yours. I did put a small bead around the base of the fixture. That's what Lance had done on the OEM
  • The clearance light in post is mounted with screws. The lamp is a twist out.
    I would not use sealant thats sets up. One that stays pliable would be my preferred choice.
    Adding sealant will make removing the lens more difficult when replacing a burnt out light.
    That gasket looks like it should seal the water out if it's not crimped during installation.
    One word of caution - there's probably a small hole on one side of the light frame or lens - don't obstruct it if you do put sealant on the assembly - the hole is for drainage and you don't want to plug it up.
