Maury82 wrote:
Lantley wrote:
nickthehunter wrote:
Huntindog wrote:
It is simple. A 250 will generally have much better durability ratings than a 150...
Really? I don't believe you. I think you're continuing to blow smoke (BS). Show me the durability rating for each.
I think one of the duty cycle issues already mentioned was Ford has no plans to put the Ego boost into the Super Duties because there are duty cycle concerns..
If you are towing within the ratings of your F-150 occasionally, I don't think there will be any duty cycle issues.
If you tow with your F-150 at your max. payload daily, duty cylce issues may occur.
I don't think duty cycle is a major factor to be concerned with, but it is a real phenomenon
I can smoke a whole Buffalo with all that smoke you are blowing...lol
I can't believe you are pushing that on vulnerable and clueless newbies under the name of an experienced member.
Towing within the F-150 capacity on occasion is ok?...lol
Just for laughs, how would towing near the max ratings of the 3/4 and 1 ton affect duty cycles?
And for an additional laughter, how can you explain the reliability of the Tundra and Tacoma?... they are reliable because the owners don't tow much?
Really depends on what your towing and where you are towing. There are plenty of 1/2 ton owners that have tried there 1/2 tons and eventually upgraded to 3/4 and 1 ton trucks.
By the same token there are one ton guys that have upgraded to duallys.
The torque provided by the ego boost is a wonderful thing, but at some point there is no substitute for mass.
If you look back in this thread some guys said they chose the ego boost package because 85% of their miles are non towing. For them I imagine the F-150 to be viable. Now had they said 85% of the miles were towing than a 3/4 or 1 ton would be a better choice.
Your bringing up the reliability of a Tacoma as a tow vehicle:h
A tacoma is a decent vehicle, but it's not much of a tow vehicle.
Tundra's are decent within their ratings but generally they are payload deficient when it comes to towing RV trailers.
Ford took the bull by the horns with their max tow, max payload package and built a 1/2 ton truck with real capability, which is why this thread exist.
Tundra and the other 1/2 tons are sitting on the sideline wondering how to compete with the payload of the EGO boost Ford.
This is an RV towing forum. The best advice I can give is to buy your last truck first. Don't play the upgrade game.
Once upon a time I towed a 11K GVW TT with a Ford Excursion. When it came time to upgrade I went straight for the dually. Not necessarily because I needed it then. But because I knew I would need it in the future.
For me the 1/2 ton truck is a temporary measure. I think anyone towing a 8K loaded or greater trailer would be better served with a 3/4 ton truck or larger. Simply because the larger truck allows one room to grow when it comes time to upgrade you won't need both a new truck and trailer.
The ironic thing in all this is it's not about money.
The difference in $$$ between a new 1/2 ton ego boost max payload, max tow and a late model dually diesel is not that great.
It's more about seeing the whole picture and gazing into the future a bit. vs. locking in and focusing on one truck and one trailer.
That is likely to change before you know it.
I know everyone is content with the rig they have and there is no need to worry or look to the future.
All 5th wheel owners said that at one time.
For those truly bit with the RV bug upgrading is inevitable. I'd be curious to know how many bought a 5'er as there 1st towable RV vs. upgrading?
If you are an OCCASIONAL tow'er that tows on generally flat ground to the beach or the local state park 6-7 times a year a 1/2 ton is fine and will meet your needs.
If you want to tow without limits, beaches, mountains, local parks, long distance destination parks and everything in between.The sooner you get a 1 ton truck the better off you'll be.
