bradg
May 09, 2014Explorer
Max Trailer
I recently purchased a 2015 Yukon XL and am looking at upgrading a Pop-up to a travel trailer. Trying to find out what size I can get is pretty confusing. The Yukon is rated with a max towing of 8500. It also has a Curb weight of 5536 & GVWR of 7300 (leaving 1764 Max Payload).
I was always looking at the max trailer of 8500 when looking at a trailer (dry weight + trailer load). However, in looking at the stats, I see the real limiter as the GCWR which is 14000. If I take the GCWR of 14000 and subtract the curb weight of 5536 of the vehicle, I get the 8500. But if I figure in cargo in the vehicle & trailer, the maximum trailer gets much smaller. For example, if I assume 1000 lbs of people and luggage for 5 people and then another 1000 lbs of trailer weight, that leaves only 6500 pounds for the trailer.
I see another bottleneck as well. The GVWR is 7300. Subtracting the curb weight of 5536 leaves 1764 for cargo. If I use 1000 for 5 people and some cargo, it leaves about 764. However, does the hitch rating need to be added here? For example, if the Dry Hitch Weight is 891, then I've blown the GVWR limitation.
Am I looking at this correctly?
1. If a Trailer dry weight is 6267, and the rated cargo capacity is 1586, how much should I figure for the wet weight? 6267 + ???.
2. Does the Hitch weight of the trailer need to be added to cargo weight for the GVWR limit? This might be the biggest limiter if so since I may make it under the GCWR limit and blow the GVWR limit.
3. On my 2015 Yukon, I have the Max trailering package. However, I can't find the limit on the included integral hitch system. Should I assume that it will handle the MAX Trailer weight? Or where do I find the limit?
