maxwell11
Dec 17, 2013Explorer
spadoctor wrote:
Radial pull is common and been around since day one. To properly determine if that is whats wrong you switch the tires from left to right....if it is the tire it will either go away or change directions. It has a lot to do with the caster built into the front end.
thanks for the reply on radial pull,
I did switch the front tires, first thing the dealer told me to do.
said he got about 2 tires a year with it.
then it pulled the other way, so we both thought, I would be golden when we replaced that one tire. did appear to work for a few days then came back, I may get an alignment before I go back.
when this set was on the back for 6K miles it drove great, problem arose when we rotated the tires front to back. I may just have the back tires remounted to the front and just drive them out, then replace them with Michelins.
guess I should not have cheaped out, saved about 150, would gladly pay the 150 to make the problem go away.
44,026 PostsLatest Activity: Feb 26, 2025
