- spectaExplorer
SidecarFlip wrote:
I have an on board compressor that maintains 5 psi in them all the time and pressure gauges under the dash with individual controls to set them with. Nothing outside, everything in the cab. Trick to long bag life is keeping air in them all the time (at least 5 psi when not in use). I installed the firestone bags in 1999 in my 1997 F350 and they are trucking right along, no issue.
Thanks on the AP tip.
I bought the cheap ones with no compressor. - spectaExplorer
otrfun wrote:
I mounted them to the plastic fender wells (next to the frame) just behind the rear wheels on each side of our Ram. Real short run to the bags. Easier to adjust pressure (and measure at the same time) if you're one that needs to level the left and right sides with the camper on-board.
This is what I think I'll be looking at.
I don't want to drill holes in the metal. - SidecarFlipExplorer IIII have an on board compressor that maintains 5 psi in them all the time and pressure gauges under the dash with individual controls to set them with. Nothing outside, everything in the cab. Trick to long bag life is keeping air in them all the time (at least 5 psi when not in use). I installed the firestone bags in 1999 in my 1997 F350 and they are trucking right along, no issue.
- otrfunExplorer III mounted them to the plastic fender wells (next to the frame) just behind the rear wheels on each side of our Ram. Real short run to the bags. Easier to adjust pressure (and measure at the same time) if you're one that needs to level the left and right sides with the camper on-board.
- Kayteg1Explorer III put mine on the floor next to driver seat. This way I could add air from 12V compressor plug into cigarette lighter socket.
Later on I put dual valve/gauges, so I could release or equalize pressure while driving.
That was on old truck, when new needs nothing. - spectaExplorer
jimh425 wrote:
I’ve had them in the fuel filler area, in the bumper, and in the fender well. The fuel filler area is ok, but the caps can be hard to get off. The bumper/plate area is obviously hard to reach with a TC on. So, I guess I prefer the fender wells even though I didn’t ask the installer to put them there. That’s probably the shortest line since each filler location is very close to the bag that it fills. I painted the white caps black, so they just blend into the fenderwell.
Thanks. That's kind of what I was thinking. - jimh406Explorer IIII’ve had them in the fuel filler area, in the bumper, and in the fender well. The fuel filler area is ok, but the caps can be hard to get off. The bumper/plate area is obviously hard to reach with a TC on. So, I guess I prefer the fender wells even though I didn’t ask the installer to put them there. That’s probably the shortest line since each filler location is very close to the bag that it fills. I painted the white caps black, so they just blend into the fenderwell.
