rbpru wrote:
Can you drill a small hole and squirt in some adhesive, then draw the panel tight with a through bolt. Or would it be better just to live with it.
That's a good thought... Hopefully the delamination is in an area with a decal... pull the decal off, drill some holes and pour in fiberglass epoxy or some other adhesive and clamp or otherwise put pressure on the delam spot. When everything dries, buy a new decal to put over the drilled holes and it looks brand new again.
Obviously find the source of the leak and fix that first though...
