45Ricochet wrote:
82K ain't to bad.
Ric: Based on the diagram you posted now I'm not so sure it's the water pump. I know a water pump on its way out will typically drip when the vehicle is parked, but the wet spot on the driveway is appearing to the right of the water pump location. Anything else on the front of the engine that could be a source? I did look at the thermostat housing, nothing appears wrong there. My mechanic is a 25 mile trip from me. Would it be safe to drive it to Orlando, or should it go on a hook?
