p220sigman
Sep 04, 2020Explorer
spoon059 wrote:
You said you guys will be pulling 12 months out of the year. A half ton is designed for occasional light towing. A 3/4 or 1 ton is designed to be worked to the max capabilities every day of the year. If I was planning on towing 12 months out of the year, I would get a bigger truck even though you don't necessarily "need" the payload or tow ratings of the bigger truck (at least not right now!) For the minimal price difference, you are getting substantially more truck. Heavier frame, brakes, wheels/tires, cooling system, etc. Your towing experience will be much more comfortable in a heavier truck as well. You'll get less push/pull in a heavier truck then a lighter truck.
This is probably the best advice you've gotten. Personally, I'd rather be on the lower end of a tow vehicles capabilities than the upper end if at all possible.
