Travelin2's avatar
Travelin2
need opinions on tire pressures
We have a little 19 foot 2014 Bullet Premier I just put on a complete new set of the Goodyear Endurance 205/75R X 14 tires. They have a "D" load rating, putting their single max load single at just over 2000 lbs. at the max inflation of 65 psi. The original tires were the same size but with a "C" load rating. They had a max load single of just over 1700 lbs. at max pressure of 50 psi.
The trailer has an empty weight of 4200#. I figure by the time I get all our junk in it and all the fluids topped up, we will probably be in the neighborhood of 6000#. That is 1500# per tire.
I would like to hear what you guys think would be a good pressure to run in these new tires. Running at max pressure would, in my mind, make for a harsher ride for the rig and it's contents.
