Question is the aftermarket camera going to work with Ford 360 system.
Small update to the linked topic where I had original cable spliced with other couplers/extension.
Over the time I found it too annoying to crawl under the camper to disconnect the cables and the other couplers are not water-tight, so I already placed order on Ford tailgate harness that will give me original connectors. I hope the 2 cables will be long enough to bring connection to the side of the camper for easy disconnecting.
The camper main plug I can disconnect on the side of the bed where I have extension reaching bumper plug.
It is not coming cheap as 2 cables will cost me about $120, but I plan to use the camper year around and the crawling that was annoying in dry weather can make bad day when you have to make it in mud.
