mbloof
Sep 17, 2017Explorer
New 2017 F250SD
Greetings, I plan on carrying the camper (Northern Lite 9.6) in the background on this truck. The two questions I have for other 2017 owners is: 1. Do I need another leaf spring? My old 97...
Kayteg1 wrote:
Question is the aftermarket camera going to work with Ford 360 system.
Small update to the linked topic where I had original cable spliced with other couplers/extension.
Over the time I found it too annoying to crawl under the camper to disconnect the cables and the other couplers are not water-tight, so I already placed order on Ford tailgate harness that will give me original connectors. I hope the 2 cables will be long enough to bring connection to the side of the camper for easy disconnecting.
The camper main plug I can disconnect on the side of the bed where I have extension reaching bumper plug.
It is not coming cheap as 2 cables will cost me about $120, but I plan to use the camper year around and the crawling that was annoying in dry weather can make bad day when you have to make it in mud.
