_1nobby
Jun 05, 2016Explorer
thcguy12 wrote:
3. So we filled fresh water tank. All was fine. Then we turned on water pump. Immediately we had drips on the outside. Some were near where we put the water into fresh tank using jugs. It drips slowly from the bottom seal outside where sink would be inside. Went inside and there are no wet spots under sink or in any cupboards. I'm worried maybe water is gathering under floor or in wall. No idea ready though how that woke system works?.
Water leaks are water leaks. No magic fix. You'll have to chase them down one by one and tighten clamps, replace chewed through lines, re-crimp PEX fittings etc.
