CavemanCharlie
Jun 05, 2016Explorer III
Jack_Diane_Freedom wrote:
For dumping why not put in a redneck septic system as we did at our wilderness property. Dig a hole twice as wide as a 45 gallon drum, deep enough to cover with about 18 inches of dirt, punch some holes in the drum with a pick axe and cut a hole in the bottom for the sewer pipe. Put the drum in the dirt hole with the bottom up. Attach pvc pipe long enough to reach the surface through the hole in the drum, with an elbow. Fill around the drum with 1" to 2" stones almost to top. Fill with dirt and hook up trailer sewer hose and dump away. Has worked for years for us.
This is terribly illegal. Around here that would get you a jail sentence, a big fine, and a permanent mark on your record that would keep you from getting a job.
