westend
Jun 05, 2016Explorer
thcguy12 wrote:OK, I'll try.
Plugged into to power....yes.
SEAM. By seam I mean outside where the vertical wall meets the floor/base. Right where those two meet. Its outside below where sink would be inside and below and to right of fresh water fill hole. No water inside.
Does this only leak when you are adding water to the fresh water fill? Does your trailer have an enclosed under belly? Does the water leak when you have the pump on or at anytime? Does the water drip only when you send water down the drain?
With a typical travel trailer, the seam you describe is not where a wall meets the floor. The exterior wall extends down below the floor level.
Is there any chance you have a phone that can take a picture?
