ScottG
Jan 22, 2018Nomad
johnwalkerpa1 wrote:plasticmaster wrote:
I'd like to install a new power outlet to use primarily for my toaster oven. The only circuit that I can tie in to is the circuit that the water heater plugs in to. Are other outlets typically tied into this circuit and would it be safe for me to tie into this circuit for another outlet? Would I be constantly tripping the breaker if toaster oven and water heater on electric were both on at same time?
It would work well if you always turn off the electric side of your water heater when using the toaster oven, but not a good idea otherwise.
X2!
