shastagary
Jan 22, 2018Explorer
Install a double outlet box with a outlet and a 3 way switch in it. Use the switch to switch the hot lead between the water heater outlet or the new outlet. You could install a small neon indicator light to show when it it is switched to the toaster oven outlet. Then your not running both at once.
