gmw_photos
Jan 23, 2018Explorer
rbpru wrote:
My solution would be to run a separate circuit for the toaster oven. My second choice would be to tap into the water heater circuit and run it on gas.
And along that line of thinking, another thing I did was to run a totally independent circuit that has a plug running out thru the bottom of the slide room. This is plugged into a yellow-jacket extension cord, that goes to the 20A plug at the CG power pedestal. I use this to run my small electric space heater and as it is, obviously it totally bypasses the trailers built in 30A service panel.
