dwright1969 wrote:
Now I'm worried. Did I screw up? I have not taken delivery yet but I am under contract. Should I try to get out from under it?
you've made a common mistake by newbies, looking at the "dry" weight, which is a fictional number made to draw in unsuspecting and uninformed buyers.
here's a quote from KZ's website:
"UNLOADED VEHICLE WEIGHT (UVW) - The typical weight of this trailer as built at the factory. The UVW does not include cargo, LP gas, fresh water,
options or dealer-installed accessories."
this means that the 3220 "dry" weight does NOT include the weight of so-called "options". such as: microwave, awning, spare tire, air cond., and so on. my Roo weighed 400lbs. more than its "dry" weight when it left the factory, due to the weights of these things.
so, that trailer will easily already weigh over the 3500lbs. max of your minivan, before you add cargo, propane, battery and water.
same thing goes for the tongue weight, which is already over your minivan's max, especially when you add the weight of the WDH.
so, unless you plan on getting a bigger tow vehicle, then IMHO, YES!
