ChrispyjCSLT22 wrote:
valhalla360 wrote:
Imagine doing normal things like cooking, sleeping, showering, using the bathroom, etc...in each (imagine being stuck inside for a couple rainy days). Then let the layout you like better decide.
I wouldn't count on quality to be much different. All the appliances and fixtures tend to be universal among all the brands.
Also, not a chance would I count on the solar/battery package running the air/con. Sure it may start it up but it won't run it long enough to be worth the hassle. Solar/battery systems are for dry camping when you have minimal electrical needs. Air/Con is easily the highest power demand of any RV system.
My plan is to not run the AC overnight while sleeping but run it during the evening some and turning it off before going to sleep.. I also have a CPAP and its hard enough for me to sleep in the heat..
I do plan to RV park camp with full hookups, boondock and dry camp..
I just want the ability to run the ac some as running it overnight is unrealistic... I do appreciate your input
As I have pointed out, running the A/C for even 1 hr is "unrealistic".
The A/C in 1 hr will use almost HALF of the included battery capacity which leaves very little battery capacity for anything else..
You have to figure in that your fridge, water heater, furnace, lights along with stereo and LP detector are all connected to and draw from that battery even when they are "turned off"..
Fridge and water heater will have 12V control boards, those control boards USE 12V in order for the device to operate.
You "need" lighting", right?
Guess where that comes from?
Yep, the 12V battery..
Want to charge your phone, laptop, tablet or even run a TV?
Yep, that same 12V battery..
Want to take a shower, wash dishes, use the toilet?
Yep, the water pressure is supplied via a 12V pump which gets it's power from that same 12V battery.
So, it has solar panels on it, big deal, 570W is a drop in the bucket to handle running the A/C and charge the batteries and you get pretty much a max of 5 peak charging hrs every day provided you have no shade, you have no clouds and lots of sun during those peak hrs. Not to mention now you must park out in the open without the benefit of trees to shade your RV.
You have been sold a "bill of goods" in believing that 400Ahr of battery is going to run your A/C for very long..
Perhaps a 1/2 hr-1hr per day provided you have full sunlight every day and you use absolutely nothing in your RV.. But even then I suspect if you do you will run out of battery very quickly.
Can it be done?
Sure, but you would need more battery capacity and more solar capacity..
Make life easier on yourself, buy a 2200W gen for the A/C, then you have less cost and less limitations for that use.
