As others have said, look at the payload sticker. The TT you are looking at has a low hitch weight (530lbs), so you will likely be good here and that's often not the case. Remember, your payload includes your passengers, gear and hitch. Check that it has the factory tow package and hopefully an integrated trailer brake. Most new trucks with tow package will likely have the brake controller, but not the case just a few years ago. For quick check on the tow package, most will have a second radiator in the grill for the transmission. Be sure to get a weight distributing hitch, may get the dealer to throw it in and hopefully set it up.
Best of luck.
