Some-beach's avatar
Some-beach
Newbie- we bought a lemon! Delamination issues
Hello. Being new to campers and getting overly excited in the buying process we bought a 2007 cub 160 off of a shady used car lot. So now we are trying to make lemonade.
The first issue we found was there has been water getting in and rotting out the bunks.
My wife and father in law cut out the bad wood and replaced it with the plastic sheeting like you might find in a shower.
The next issue is around the side market light all the way up to the side of the window is delaminating on the drivers side of the camper. There is also a large very soft spot about 2ft by 2ft underneath the bunk in the front.
My question is on the side of the camper if you we going to try to use epoxy to rebound the delamination would you try to take out the window and go in that way? Or try to go up through around the marker light?
Second question is on the front where there is the big soft spot where should I start? I can't see the back of it bc there is a bulkhead? That blocks what I can see. Should I cut a hole on that and just see what I can see and go from there?
The picture is hard to see but on the left is the access or side storage door and the bulk head thing is what the wires go behind.
