rubsal70 wrote:
@miltvill really 6-7mpg??? I usually get 14-17 without towing. That seems awfully low.
@handye9 well when we go out tent camping or to the coast and rent a home for vacations. We usually don't buy anything until after we have settled in. We take clothes, fishing rods, empty coolers, (tents, sleeping bags, camping stuff when camping), empty buckets and that is it. When we plan on going with our TT we will try to limit also like when we go any other times. I won't need to add water cause they have it at the sites and also dump stations are at sites. I will take the payload seriously though and probably go to a weight station.
@larry and gmw photo how much of a difference would I see in my mpg if I go to a 3.73 or 4.10
You guys are right I will not be towing everyday. I will do towing maybe about once a month at the most and summer twice a month but that is it.
Thanks for all the help I appreciate and I am learning a lot.
Regarding gas mileage, it's probably fair to say that it's typical to see the gas powered tow vehicles use "almost" double to double the fuel compared to non towing.
Example in my case, pulling this Funfinder with the Nissan Frontier ( 4.0L V6 gas, six speed manual ) I get between 17 and 23 mpg non towing, and between 9 and 14 towing. The overall average for a long trip with the trailer is always right around 12.3 to 12.5.
Here's a another real world example for you to chew on: we also have a one ton dually ( Ford powerstroke diesel ) with 4.10 gears. It gets 9 to 11 mpg all the time....does not matter if it's empty or pulling the 35', 13,000 pound horse trailer, or the 14,000 equipment trailer loaded with hay.
You will need to simply accept that towing and good gas mileage just do not go together.
As for the difference in fuel mileage if you were to switch from a 3.23 to a 4.10, I am going to make "guess" here ( and I stress this is just a guess ) that your towing mileage is probably going to be about the same with either gear. Your non towing mileage is probably going to be from one to three less with the 4.10. Probably about one to two mpg worse in city use, and two to three worse on highway cruising empty. Those are my guesses.
