Jbird2200's avatar
Jbird2200
Newbie here, advice on tow rig?
To preface, sorry for the long first post. I've read about 50 pages of the diesel vs gas thread and it's exhausting, so I thought I'd start my own in hopes of getting some realistic non-biased advice.
Need help deciding on which truck would be best for my specific use, I know this debate has gone on for decades, but I hope my specific scenario doesn’t turn out to be beating a dead horse.
How I will be using the truck:
I will definitely be buying used, likely in the sub $25,000 range.
I work less than 1 mile from my house, as of now, I drive to work (lazy) and drive my own truck (a OBS GMC ½ ton). I could easily take the wife’s car to work if I wanted to still drive to work as my shift is overnight from 9pm to 7am and she rarely needs to be anywhere at those hours. I also work every other week (7 nights on, 7 nights off), so my truck generally sits every other week as it is.
We are planning on getting a toy hauler camper. The current model we are looking at has a manufacturer dry weight rating of about 6,000lbs, but I’ve been told that those are typically underrated, and a fully optioned unit would run closer to 7,000lbs as a realistic number. Add motorcycles, weekend supplies, fluids, etc, and I’m thinking the max load should be under 9,000lbs for sure. This is assuming we go with the unit we’re looking at which is about 30ft, bumper pull. I would like to have the capacity to go larger if I were to find a good deal on a different trailer, but at the time, we’ve pretty much decided on the model.
So, given that the truck will sit most the time, it will not accrue a lot of mileage. I’ve only put 5,500 miles on my ½ ton in the past year, but it has not been used for towing an rv, so as we will start doing that, the annual mileage can expect to increase somewhat.
At first, I was set on a 06’ or 07’ 8.1L w/Allison 6 speed, as fuel consumption shouldn’t be a huge issue considering the annual mileage. But now am second guessing the option of diesel.
I have never owned, diesel, but am aware of many of the nuances that go along with owning one, filter changes, oil capacities, warm up/cool down times, etc. But I am having a hard time coming to a decision as to which gas vs diesel I should be considering. The 8.1 truck seems hard to find with reasonable mileage at a reasonable price, and the only ones in my area that have popped up are asking almost diesel prices ($20,000 for a 2006 8.1 w/ 77k miles for example). I should note that I am not necessarily brand loyal, but have had decent experience with GM trucks, and as far as gassers are concerned, I’m really only considering the 8.1L big block.
Thoughts? Anyone have experience with the 8.1 pulling a comparable load?
Sorry for the novel, I just want to invest in the right truck for the job, and that will fit our use best.
    Now that's funny! :)
    But really, for the mileage you're talking about towing I could live with any engine in any vehicle rated to tow (and carry) the weight. If you go diesel you may want to get one old enough not to have a DPF. It doesn't sound like you would routinely drive enough to keep it regenerated.
