word's avatar
word
Newbie Needs Help
Hey all...just now getting into the Travel Trailer market and wanted some recommendations. Looking to get a used trailer and have absolutely no idea if any make or model is better than the other. I'm on a tight budget, so when I say used...I mean used. From what I can gather from pictures, the ones I'm interested in have potential, albeit in need of some elbow grease. Anyway...does anyone have any thoughts on the following
1988 Nomad by Skyline 24 ft
1979 Skyline Laton 22 Ft
1987 Coachmen 28Ft
1992 Sunline...not sure on the length yet
1979 Wilderness 24Ft
Anything and everything would be appreciated. As well as any thoughts on what to look for in these older travels.
Thanks all....appreciate the help
  • In my opinion, if any of them are still on the road, they must all be good.
    Good point
    As stated above ... water leaks. If there's evidence of a water leak, PASS!
  • Appreciate the insight. Any of the above Models have a better reputation than the other...in your opinion?
    Thanks again.
  • Once you get back into those range of years you can expect anything and everything to work or not. For something that old it's on a case by case basis. You can find some remarkable units and some that haven't seen anything running but water into them. Leaks are the #1 thing to check, once they leak from the roof or windows it becomes a lot of work to restore. Also, check running gear and tire wear. Any wear on the sides of tread will indicate a potential axle problem.
