Led_67
Dec 13, 2013Explorer
If this camper is as you described and does hang over quite a bit and also considering where you are going then I would recommend that you get Torklift frame mounted tie downs and the proper tie downs. Good luck
According to some searches for your TC I have come up with a dry weight of 3200 lbs. and if you look around inside your TC I bet you will find a mnanufacturers tag with those specs as well as capacities for LP, water, and other various info.
44,066 PostsLatest Activity: Jul 25, 2018
