Ronbo1821
Dec 11, 2018Explorer
thanks for all the advice folks, looks like I will block it, take wheels off, try to seal any opening that mice & rats will try to get into, spray foam on tanks, wrap any exposed pipes with foam tube, install a few lights underneath and then skirt it. Not sure if I'll get to all that for this winter so I'll make sure it's winterized and just use my bucket toilet for now until the spring.
The guy I bought it from had the water hooked up when he showed it to me so I can see everything worked. I opened the two valves to empty the water from the black & grey tanks but I didn't know about the water heater so I'll have to empty that as well and look for the low point drain to get the water out of the fresh water tank. I don't have an air compressor so cant blow the lines yet.
44,056 PostsLatest Activity: May 04, 2014
