SoundGuy
Apr 19, 2016Explorer
#1nobby wrote:
So....I think I found a solution for the batteries.
I realized that 2 batteries will fit that bracket and once installed, will be hidden by the aerodynamic panel. I can remount the propane tray on the A frame with one of those plastic covers.
As long as you don't create any clearance issues with your weight distribution or tow vehicle then this should work just fine. Ironically I'm in the process of doing the reverse - moving my tanks from the front of the A frame just aft of the tongue jack back to the battery rails by the trailer front wall and moving the battery forward on the A frame. Also gives me sufficient room for a second battery box that will hold my fresh water transfer pump. While you're at it you might want to paint the A frame and add a platform to the A frame ... I've used 1/2" plywood for this on past trailers, for our current one I'm using 3/16" diamond plate. Eventually I'll post pics in my gallery once the project has been completed.
44,070 PostsLatest Activity: Jul 01, 2022
