_1nobby
Apr 21, 2016Explorer
Getting ready to install the dual 6V batteries.
I decided to remove the enclosure panel to see where all the wiring went....and found the box.
That was good as the trailer to truck harness had a damaged plug and it was about 6" too short for me to be comfortable. I was able to cut off the bad end and re-route the cable to gain about 8". I then put on a new plug.
I also installed some wire that will later terminate in a switch that will control the trailer running lights when not plugged into the tow vehicle.
44,070 PostsLatest Activity: Jul 01, 2022
