SoundGuy
May 04, 2016Explorer
#1nobby wrote:
Tight bloody fit. I had to remove the tongue light assembly for it to work.
Any ideas of a readily available material that I can patch that spot up?
Ditch the tank hard cover, use a vinyl cover instead, and you may have enough room to put the light back where it belongs and even sufficient space to mount a power tongue jack, especially one that allows mounting so the head is facing 90 degrees to the side as is the case with my new UltraFab 3502.
44,070 PostsLatest Activity: Jul 01, 2022
