SoundGuy
May 23, 2016Explorer
#1nobby wrote:
So....I bought a new and improved Shurflow pump.
And the plumbing is now serviceable.
A couple of suggestions ...
I see no filter on the input side of your new SHURflo Revolution pump so unless there's one located elsewhere it'd be a good idea to add one.
With just 4" of braided hose connecting the pump output to all that awful hard wall PEX you're sure to hear that pump rattling away every time it runs so if you have sufficient clearance you'd want to mount the pump on a soft pad to minimize vibrations from being induced into the floor. Secondly, you can also dramatically reduce pump vibrations from being induced into all that PEX by replacing that short piece of braided output hose with a large loop of soft wall potable water hose. I used a 25' potable water hose, converting the ends to the required NPT fittings and can barely hear my own Revolution running. Proof is here - 3 pics, 1 video.
