krazymatt's avatar
krazymatt
Newer Cummins with Exhaust Fluid
I used to own a 2008 Cummins and although I never had trouble with it I heard many folks having issues with the emissions back then. I'm tossing around the thought of getting a 2015 Cummins and I'm just wondering what they're like now with the exhaust fluid? Are they pretty reliable? Does the fuel economy still around 12mpg empty? Thanks for any info I can get on this truck. I understand all Diesels these days have the exhaust fluid but if I got a truck it would be more likely a Cummins as they are better and cheaper than Fords and Chevys usually. Thanks....
  • That can be misleading at best. Because of the increases in HP and Torque fuel economy starts out worse. Heck, my 07 6.7L dually with 4.10 rear end returns a steady 17 at 70 MPH without DEF. Towing is 10.5 to 11.5. All hand calculated. That is every bit as good and in a lot of cases better than the new DEF equipped trucks are capable of with "better" rear end ratios.
  • Thanks! Very informative. So it appears these newer trucks might get a bit better mpgs? I talked to a guy who has a construction company and they have a 2015 dually and he said it got 15mpg from the get go so I'm assuming they're maybe going to be a bit better? Thanks...
  • Interesting read here about DEF.
    7. DEF will kill my fuel mileage.
    Quite the contrary. Because the manufacturer is able to tune the engine any way it wants to, and then allow the SCR and DEF to take care of the pollutants, most manufacturers have discovered better fuel mileage (compared to other smog-reduction systems). Truckmakers claim it improves fuel mileage by as much as 5 percent.
    That should get some good comments. :S
