pmlevine's avatar
pmlevine
Nissan Frontier towing Winnebago Micro Minnie TT
In June we purchased a 2016 Winnebago Micro Minnie 2106 FBS trailer trailer, and decided to purchase a 2016 Nissan Frontier as the tow vehicle.
I had some concerns about the ability of the Frontier to safety tow the Mico Minnie, (weight and handling) thus far we have taken 4 trips with this combo, and all has gone well regarding handling and braking. In fact towing has been enjoyable.
The Frontier has a 4 liter engine, crew cab, automatic transmission, is outfitted with an Equalizer 4 point anti-sway weight distribution tow hitch, and an aftermarket electronic brake controller installed in the cab.
We chose the Frontier primarily due to size: when using as a general home vehicle - parking, and my wife has some health issues so vehicle height was an issue.
We knew mpg when towing was going to be poor, but decided we would live with this downside. Upon seeing a hill in the distance, proactively accelerating to build rpm works very well, in fact, when approaching the top of the hill I back off the gas pedal, which seems to work fine, the "rig" pushes itself up and over the hill with the momentum.
Phil
7 feet wide, 21' 11" long
3705 lbs max dry weight
(360 lbs max hitch weight ? need to confirm this)
dual 3,500 lbs torsion axles
14” nitrogen filled radial tires
NXG frame
3,295 lbs cargo carrying capacity
Nissan Frontier SL 2016
GVWR 5815 lbs
GVWR FR 3296 lbs
GVWR RR 3331 lbs
Equalizer 4 point anti-sway tow hitch
https://photos.google.com/album/AF1QipMg70U1NPnE7sQ9bMHOAgeXfdd-I-8xH_U8fDta
  • Glad it is working out for you!
    I'd suggest you take your trailer and truck to a scale to see what you are actually towing regarding the weight.
    With a listed dry weight of 4K lbs, I'd bet your tongue weight is more like 600 lbs. That might leave you little room for cargo, depending on the specs for your Nissan.
  • hmmm , I must be missing something . As far as I know the max. tow cap. is 3500 lbs ,suitable probably to pull a pop up camper loaded with gear . Am I missing something ?
