Bionic Man wrote:
Turtle n Peeps wrote:
Perrysburg Dodgeboy wrote:
241HP 550FT/TQ so it's making the same TQ with lower HP. can't wait to so these two on the road.
Don
Come on over and drive my 6.5 diesel with a TT on the back. It has a little bit more torque and a little less HP then the "Eyetallian Cummins." It will feel almost exactly like this new Ram.
Power aside, the RAM will have twice the gears as your 6.5 and likely be quite a bit lighter. Not really an accurate comparison.
Gears does not make trucks any faster towing up a hill. Well, not appreciably any faster anyway. The only way to fix that is with HP. Put 8 or 9K of TT on the tail of that 1/2 ton and see what happens going up Eisenhower Tunnel.
I said it once and I will say it again; the EB is going to waste this thing in a towing test. And that will end the love affair to this thing with most people. Over a 125 more HP. It's not even going to be close.
So, your saying that having more gears which would allow the engine to spend significantly more time in the powerbad would not result in the ability to maintain higher speed up grades? I disagree.
I do agree if you are looking for a drag race up Eisenhower (a pass I pull several times per month in the summer) that the EB will win. I also contend that the diesel will return SIGNIFICANTLY higher MPG, both towing and solo.
We shall see what is more important to the consumer. My guess is that there will be plenty of people that want the MPG. My guess is also that Ford will sell more EB trucks than RAM will sell 1500 diesels. But that does not make the diesel a failure.
Significantly, no, it just won't make that much difference.
If we were talking about two stroke motorcycles with a peaky torque band my answer would change. If we are talking about a gasoline race engine, or even just a gasoline engine, my answer would be different.
We aren't; we are talking about diesels with a broaddddddddddd torque band.
If you drive a lot of diesel trucks you will soon learn you don't need to shift them a lot. At least a lot less than a gasoline engine of the same power rating. With a gasoline engine you can pick up a lot of RPM and speed if you just grab the next gear. Not true with a diesel. This is really true of the big 6 because they are know for torque.
Will this thing be a success? I have no idea? I do know this; historically, the American public hates underpowered vehicles and a lot don't like diesels. This is not the first time a manufacture tried to put an underpowered diesel engine in a truck or car. Look at the 5.7 diesel in the pickups. What is a success? Nope.
Then there was the 6.2 diesel in a pickup. Was it a success? Not really. The VW diesel Rabbit, nope. Look at the VW TDI. Do they sell a ton in the US? Nope. Every one of these cars and trucks I have mentioned got FANTASTIC fuel mileage but did the public flock to the dealerships to buy a diesel? Nope.
Lets face it, this thing is underpowered by todays standards and by the competition. I don't care how many gears you give this thing, the EB will make it look silly in a tow off and Ford is going to play that card for all it's worth.
Do they plan to start out with 240 hp and then down the road turn the wick up on this thing? Maybe so? Look a the Dmax. So if they made room to grow with this engine and can get close to 300 to 330 hp out of this thing, reliably, it may not be a bad deal. :)
