- GdetrailerExplorer III
rlw999 wrote:
Correct, it is rather confusing that the RV industry decided to call the battery charger/power supply a "converter". While it does "convert" 120V to 12V in some respects it should have been called a battery charger since that really was the prime reason for the converter to exist.
Then you'll get questions from people asking "My RV only has a battery charger, how can I run my 12V appliances when plugged in to shore power?". And really, I use my converter as a DC power supply much more than I need to use it as a battery charger.
I don't think there's anything you could call it that wouldn't raise questions from someone new to RV'ing, but once they learn, then calling it a "converter" is no worse than anything else and they quickly learn the difference between an inverter and a converter.
If you called it 12V POWER SUPPLY AND BATTERY CHARGER there would be zero questions. Spells out exactly what the function is.
Calling it a "converter" just makes a muddy mess since folks think it CONVERTS 12V to 120V..
Both converter and inverter "convert" and hence the confusion which could have been easily avoided. - rlw999Explorer
I don't think there's anything you could call it that wouldn't raise questions from someone new to RV'ing, but once they learn, then calling it a "converter" is no worse than anything else and they quickly learn the difference between an inverter and a converter. - trail-explorerExplorer II
enblethen wrote:
A good way to charge phones and other electronics devices is a USB receptacle
They are easy to add. - mockturtleExplorer II
- coolmom42Explorer IIIf you have a 12 V outlet in the RV, you can get a small portable inverter with USB outlets to charge your phone, and a regular 120 V outlet to charge a laptop. You might also invest in a "battery bank" for cell phones so you don't have to charge so much, or in a small solar panel with appropriate chargers.
If you are out driving around in your tow vehicle, plug the inverter into your 12V outlet in there. A couple of hours should charge a phone and most laptops. - GdetrailerExplorer III
wnjj wrote:
It’s probably because early model RV’s only converted and didn’t charge the battery. My sister’s previous 88 Coleman tent trailer had a switch between “converter” and “batt”. You had to charge the battery externally. Inverters also weren’t on the scene so converting was only in one direction, hence why they are now “inverters”.
I think the proper term for what most of us have is “converter/charger”.
My Dad had a late 1970s TC which had a "converter" and no battery on board. Since no battery was on board of the TC and all the lighting was 12V the converter was a "power supply". Which is what the device is and should have been called.
When you work on electronic equipment, absolutely no technician will refer to a power supply section as a "converter". Nope, they call it what it is, a power supply.
Does a power supply "convert" voltages? Sure, but its function in life is to provide the correct voltage and amperage to your device and in the case of typical RV takes 120V and reduces it to 12V to provide power to your 12V items and charge the battery. In other words power your devices that work off of the battery.
Keep in mind, an "inverter" also "converts" from one voltage to another and that is why folks who buy a RV get so darn confused thinking they can plug in 120V appliances when not connected to commercial power grid or generator. - LwiddisNomad IIII suggest you read the basics on RV electricity. It is not hard but it is different than you are accustomed.
- dodge_guyExplorer IIAn inverter is easy to install with a dedicated outlet or 2. You will need 2 good batteries. Possibly solar if you aren’t going to be plugged in for a few days.
- wnjjExplorer II
44,068 PostsLatest Activity: Jun 10, 2026
