rmaukExplorerJul 12, 2021No power to outlets when in battery mode.2017 Coachman Viking 16RBD. When plugged into electric everything works fine. When on battery, no power to the outlets, microwave, nor A/C. I've hit reset on all of the GFI protected outlets, checked...Show More
enblethenNomadJul 12, 2021Your receptacles and A/C are 120 volt volts. In order for them to work off batteries, you would need an inverter.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problemPower outlets not working on battery power
