hedgehopper's avatar
hedgehopper
Noisy fan on range hood
Our 2002 Northern Lite 10-2 CD has a range-hood fan that is loud. Have you replaced yours with a less-noisy one? What did you use and is it satisfactory?
  • fpoole wrote:
    and the vent flapping in winds... 3am of course... flap, flap, flap..... since they are related? if not, delete this post. thanks.
    My 5th wheel vent flap has a locking tab so it doesn't flap when going down the road. I just lock it down on windy days when the range is not in use. I probably will install something on the TC to do the same.
  • 2oldman wrote:
    Put a sock or a bag in the outside vent cover.
    Kewl, heheh, will try that... like "Put a sock in it.' thanks 2OM.. appreciate it..
  • There was a post a few months back about using a computer fan with good results .
  • 2oldman wrote:
    gregchambers wrote:
    http://www.amazon.com/gp/produ...00?ie=UTF8&psc=1
    Link no work. Periods indicate missing code.
    the flap on my TT has little flip out stops to prevent that. wondered why they put them in. :)
    bumpy
  • The following is a variable speed fan control that allows you to tune the fan down to an audibly acceptable level. It takes drilling a small hole in your hood for the control knob and somewhere to hide the controller ( I was able to mount mine in the sheet metal cover under the hood that hides the wires from the controls back to the fan/light) but it wasn't difficult to install and the wife loves it. Not bad for $10. You can use the fan at full speed if needed but most of the time we have it on 1/2 speed which is much quiter and all that is needed.
  • Hood fan sounds awful! I always imagine the tips of the fan blades being flat from where they rub.
  • and the vent flapping in winds... 3am of course... flap, flap, flap..... since they are related? if not, delete this post. thanks.
