Dayle1 wrote:
06Fargo wrote:
NC Hauler wrote:
jims1 wrote:
I too am making this leap to the dark side. What alot of folks don't realize is that their Dodges, Fords, and Chevy's are not built to handle the advertised weight ratings day in, day out. We tow 17.5-18k depending on the level in the tanks. .
Some truth to that, but there are also a lot of us out here who do know what they're doing, can do the simple math and know what we need to tow with. My 2013' Ram 3500 crew cab, long bed, 4X4 Dually, with 4:10 gearing has a GVWR of 14,000#, with a RAWR of 9750# and a GCWR of 37,000#. My 5er has a GVW of 16,950#, loaded to 16,050, with a 3300# pin weight. CAT scales has my truck loaded, ready to hook to my 5er with full tanks,5er hitch, wife, pets and toolbox @ 9,420#. That put's my loaded truck at a weight of 12,720#( 9420# plus 3300# pin weight), and total weight of 25,470.(5er @ 16,050# plus truck loaded weight of 9420)) So as you can see, I'm 1280# under my trucks GVWR, and WELL under my trucks GCWR and doing it all with a 1 ton crew cab dually which, at this time, has to also be my daily driver.
You're basically saying, those that tow well over their trucks limits day in , day out, won't last.. I agree with you on this, if it's what you meant. But i also believe if one has matched the truck with what they're towing, and is maintained properly it WILL perform day in and day out, just as it was designed to do.
My truck also has the medium duty Aisin transmission option in it, which, which makes my towing combo of Cummins/Aisin a little more robust, capable of towing even your examples of a 5er in the 17.5-18K weight range with just the 1 ton dually....
Any speculation at all why Chrysler engineers (lawyers?) rate a pickup for 37,000lbs GCWR, but it is not rated to haul the sum of it's two axle ratings without a trailer?
There is a simple answer to that and it's called loading. Inexperienced auto/LDT owners will load a vehicle to it's GVWR and NOT pay attention to GAWR or tire loading.
Dayle, that's been my point for quite some time now. AND, you don't have to be an inexperienced auto/LDT owner to overload your tow vehicle. As you should have seen in here for quite some time now. There are far more in here who don't look at or care for the GVWR numbers on a truck, some may care about GCWR, but it too, is mostly ignored, and as they'll point out, there is no carnage on the road, so it's ok. Most WILL look at their RAWR (when discussing cargo carrying capacity in bed of truck or towing), and use that number, again, totally ignoring GVWR....Most will tell you it's just a number and means nothing, and to a point, they're right....you DO have the rear axle rating hanging out there to lap up anything one throws in the bed of the truck, but at what point does one dig deep enough into the trucks rear axle weight holding capabilities? At what point does one start wearing out bearings, stressing spring packs, abusing shocks, pushing limit's of the drive train and so on?? Most don't care, they just "hook up and go". Add tires that will carry more weight, possibly exceeding the weight carrying capabilities of the rear axle itself, thus making it the weak link....it's rare you see this, but do know I've seen one case on the cummins forum.
Manufacturers do have built in safeguards to keep from living with lawsuits when people overload their vehicles...thing is, I don't know at what point one has taken away from some of the safety factors offered by the truck or at what point one starts tearing up their truck, I really do believe that the Engineers that design and manufacture these vehicles DO know the answers and put their "numbers" on the vehicle...to cover them and the owner...but there is a limit to those numbers, but "I'M" not going to ASSUME to know them.
So you are right, simple answer, not so simple and it's not alway's those that don't know what they're doing..some do it because everyone else does it and nothing has happened to them....
Some DO know what they're doing and know enough about the tires, suspension, axle etc...weight ratings to not exceed those and everything is fine...So, as the owner of an expensive tow vehicle and possibly a very expensive TT or 5er one is towing and possibly carrying precious cargo, (ie family), I tend to err to the manufacturers recommended towing weights, run all tires at recommended tire pressures and don't tow over 65 mph, more like 55-62 mph....figure I'm doing everything within my power to protect my family and my investments....just the way I am....I know most don't agree with this, but we're all different and do things differently and that's the way it's been and probably alway's will be.
