MikeJinCO's avatar
MikeJinCO
Older Bigfoot Taillight question
Our new Bigfoot is a 2003 25C9.6. We have the two piece square tail lights with the outer being the running light/brake/turn. The inner has a red outer and clear square center for backup. On braking only the outer light comes on, thI would think e inner only seems to light up on backup and the red outer ring never comes on. that both should light up. Question is how should they work? Could someone with a Bigfoot of about this vintage and taillight arrangement go see how theirs operates for me.
Thanks
  • Thanks for all the answers, they are Bargmen lights. The inner is only a backup so I guess they are fine. We're shipping out to South America in November so the learning curve on this one needs to be steep.
  • I'm not going with LED lights. They burn out all too often and can't change the bulb. I knew there had to be a trade-off about them.
    Thanks
    Our Bigfoot is a 2000 25c9.6 like yours... Lights work exactly the same as yours...
    The backup light glows red along with the white/clear lens. The combo color lenses are not partitioned to do what you think it should..
    The outer solid red glows for parking and bright for brakes... 2 elements in one bulb. The backup light are single element.
    Jim
  • My TC isn't that old.
    I did upgrade with L.E.D. tail lights, and mounted them higher on the TC.
  • Reddog1 wrote:
    Older Bigfoot Taillight question with a Bigfoot 2003 25C9.6 TC. You youngsters ain't older than my 1988 Bigfoot. :B
    I can't help you with the lights, I think mine use kerosene.
    Wayne
    Not sure on this, but I think they use whale oil. Very efficient.
  • I have a 1993 Lance... with same light configuration... the red ring around the back up light is merely a reflector...
  • Older Bigfoot Taillight question with a Bigfoot 2003 25C9.6 TC. You youngsters ain't older than my 1988 Bigfoot. :B
    Wayne
  • Bargman lights? If so the inner fixture is only b/u with reflector around it- no other light function
    edit add pic
