jshupe wrote:
To say they are laden with issues is a blatant exaggeration.
Spend some time on the Powerstroke 6.7L facebook group or on any powerstroke online forums. What is the first recommendation you get on these forums? Install a CP4 disaster kit or a fass lift pump. 2nd recommendation? Delete the emissions system. 3rd recommendation? Oil changes every 5K and fuel filter changes every 10K miles and DO NOT FORGET TO USE A LUBRICATING ADDITIVE (!). If these new diesels were so great and reliable, why spend $3-4K on these changes (and void warranty and go illegal)? Why accelerate the manufacturer recommended maintenance schedule? Ford says you don't need to use an additive but will not cover the CP4 pump failures...
My '16 Powerstroke had TSB 16-0041 at 4,000 miles (emissions system). At 15,000 miles a new water pump. At 30,000 miles a left lean bank sensor. At 40,000 miles a slow coolant leak that nobody has been able to find and I am now at 52,000 miles. Is it leaking out of the radiator cap? Out of the radiator inlet? At the off-gas bottle cap? At any of the hose fittings? Maybe it is leaking into the intercooler? Who knows? The engine is so crammed you can't see anything and it passing all the pressure tests....
jshupe wrote:
And not everything is about cost... you don't buy a Corvette over a Spark for economy, yet they sell plenty of them and don't kick up the same amount of dust the diesel vs gas debate does.
Sure, if you have money coming out of your ears, it is never about cost ;). Besides, you are talking about extremes (Corvette vs Spark but there are MANY alternatives in between at all different cost points). I am talking about two classes of vehicles - one that fits most people's needs (esp. with the new 7.3L Ford gas and 6.6L Chevy gas offerings) and another - that has become a super expensive monstrosity that is not even that reliable anymore.
jshupe wrote:
I had a CP4 failure covered under warranty on my 335D
So you did have a CP4 failure? ;) What was the bill? $10K? $12K?
Lucky you warranty covered it. Ford is not covering them, that's why there is a class action lawsuit.
jshupe wrote:
after that converted my GM LML to a CP3, and will do the same for my Ram when the warranty is up.
Why? If diesels are so reliable.....
jshupe wrote:
I have absolutely no concerns about my diesel
I was talking about money - what modern diesels cost to maintain/operate and the issues they are seeing.
jshupe wrote:
Vehicles, with few possible exceptions, are pay to play, and people buy what they want. Very few buy just what they need, or else there would be a lot more people hauling with basic work trucks and commuting in econoboxes.
People buy what they are programmed to buy or what others tell them to buy. "Hey guys, I bought a 10K lbs travel trailer, what truck do I get???". "Buy a diesel! They last forever and they have awesome power!". I am here to tell you that this "diesels are indestructible" myth is based on old and simple diesel machines of the pre-2004 era - those were cheap AND simple to operate! New ones? Nope.
Like my 1970 Massey Ferguson tractor with the legendary Perkins diesel engine - compare that to today's emissions laden Masseys that mandate that a farmer has at least two tractors - a new one and a 50 year old one for when the new one fails....
IMHO most people have no idea about towing capacities and payloads. They just buy whatever they think is adequate or whatever they have heard from someone is adequate (salesman, online RV forum, whatever). If people bought based on educated decisions (cost of ownership, payloads, towing capacities etc. etc.) - most would NOT own a today's diesel.
jshupe wrote:
Two final points:
- The value of exhaust braking in modern diesels should not be overlooked if you are traveling in the mountains
I agree, easier to tow with an exhaust brake but gassers have natural engine retardation so that counts for something at least.
jshupe wrote:
- Diesel variants usually come with stronger transmissions, transfer cases, axles, etc, and that is part of the premium
Hmmm. An F-250 gasser and F-350 gasser (in the SRW version) will almost always be rated for more payload because the gas engine is lighter than the diesel so at least in "legal" ratings with in a particular GVWR it will have more payload. The 7.3L Godzilla gasser Ford comes with the same 10-sp tranny as the equivalent Powerstroke. As far as I am aware, the same axles etc, are in the gassers and diesels up to and including the 1 ton trucks. A lot of the time they get artificially de-rated (on paper) to fit a lesser class of truck. It would not make any sense for the manufacturer to use different axles on an equivalent F-250 or F-350 gasser/diesel trucks. In fact, the "new" 10-sp tranny used by 2020/2021 Ford gasser/diesel offerings is built by GM and there is a rumor of a 10sp 6.6L Chevy gasser for 2022....
