tonyandkaren
Apr 27, 2015Explorer
Yes, there are thousands of satisfied customers but just like anything else you really do have to keep up on the maintenance or you will have problems. Leaking roof are caused by poorly done caulking and lack of maintenance. Mold is caused by leaks and lack of ventilation especially if you spend a lot of time in a wet climate.
In over 20 years of fulltime RVing we've had one mouse get into our engine, none in the RV itself. We've had several ant invasions though. Make sure you do not have any holes where rodents can enter.
Plumbing and electrical problems can happen anytime. It helps to know how everything should be working and what you have to do to fix any small problems before they become major problems.
When you get your RV inspect every inch. If you see anything that doesn't look right take it back to the dealer. If it's something small and you have the expertise, fix it yourself. You'll probably do a better job in a shorter amount of time.
Good luck! Enjoy your trips!
