2012Coleman
May 06, 2015Explorer II
GolfOCD wrote:Sorry - your going to be mad at me, but I think you have your head in the sand. Your still quoting dry weight and you only think a brake controller is necessary? I mean really? Your going to be towing in excess of 7500 lbs with 1/4 ton PU and you don't understand the need for a brake controller? Do you think your Tundra can stop all that by itself?
Thanks all, based on the info here, it looks like the 28BHBE will work. Per the specs, the dry weight is 6100# and is 28' which should be fine for our truck. We have five, so we need a little extra room, especially on rainy days.
And as far as the brake controller, I was told they were necessary. Are you all saying that maybe it is not? For <$200, I'm probably going to get one to be safe.
Again, thank you all. Buying a TT is a tough decision. There are almost too many options. But, we should be able to find the "perfect" one.
Good luck - based purely on speculation - you should be fine?
