dadwolf2
Jan 25, 2014Explorer
joerg68 wrote:
I have an Apex 8 LB with a cassette toilet and a retrofitted SOG fan. The SOG lets you use the cassette without any chemistry.
We used to have an older Lance camper with a black water tank, so I know the difference.
+ dump in any toilet, anywhere. To winterize, remove & clean cassette
- limited "capacity" - about 2 days for 2 adults. You could carry a spare cassette (although I don't know where in our rig). The cassette is somewhat heavy to carry around when full. And it should be rinsed regularly; not everyone likes to do that.
I would not want to go back to the black water tank solution.
There is a known issue with the cold water line that feeds the toilet. It blew on our installation, and on some other members' campers as well. Personally, I believe it was built up back pressure from the water heater. It has not happened since we depressurize the system while the water heater is heating. Obviously this is a primitive fix that you may not like. Someone here on the forum has installed a pressure regulator in the line; you might use the search to find the article.
Terry Rey I believe was the first to install the pressure regulator and I followed suit. Simple install that has worked well.
44,056 PostsLatest Activity: Jan 12, 2020
