cnieto wrote:
I have a 12V panel like the first one but have yet to find a 120V panel. But if I have power to the GFCI which I'm guessing is 110 then the problem would be in the trailer not the pedestal (correct). Don't know called a guy yesterday he charges $50 to come out and $92/hr. So I'm gonna bite the bullet and let him figure this one out. I hate to do so I like to figure stuff out for my self but this time its really irritating. If I change out the outlet that started this issue would that help I looked at it and it looked fine. But sometimes they go bad and look fine. Just guessing at things now hate it when I can not figure things out.
Just to let you know since no one else has since pics were posted. The top pic is a compo 120volt and 12volt panel usually used in all types of RVs. Also a point to look at is with power off pull out offending recptical and make sure the wires are tight in it, you will be supprised with what you see if you are execting it to look like the ones in your house. They do come loose. If you think it is ok then try to find the one in front of it and pull it out. Several recepticals run off of one c/b. Good luck.
