feelgood's avatar
feelgood
Payload an issue?
Hello all,
This is my first post ~ your help would be greatly appreciated. My tow vehicle is a 2006 Ram 2500 5.9 diesel Megacab 2WD SLT. Specs say my max trail is 12,900 and max tow vehicle payload is 2,040.
We are set to purchase a 2015 Jayco 32TSBH, weight completed at factory w full propane tanks: 8,440
From reading the forums I have gathered that, to establish my payload I need to add the estimated hitch weight of the trailer + everyone + everything that I put in the truck during tow.
Here's what I came up with:
8,440 dry + 1000 lbs in trailer = 9500 lb trailer when loaded
Estimated hitch weight = .15 x 9500
Estimated hitch weight = 1,425
Weight of my family of six = 645 lb (myself, wife, children ages 11, 7, 4, and 2)
If I've figured this correctly my payload with just the estimated tongue/hitch weight and my family is 1,425 + 645 = 2,070
That means the payload of the truck will be exceeded by 30 lbs !!!!??? and I havn't even accounted for anything else I want to put in the truck besides my family (and the kids have plenty of growth yet).
Does this mean I need to get a 3500 to do this (payload of the 2006 3500 is an additional 800 lbs over the 2500).
Thanks in advance for your advice!
  • Is there anyway you can get the dealer to weigh the tongue of the trailer? Most all have a Sherline scale that they can use with very little effort on their part. If not, maybe you could purchase your own, not only for this fact finding effort but also for future use. When we had our TT, I had one and used it every time we loaded the trailer for camping. That way, I was always absolutely sure of the trailer's tongue weight and I could adjust moving things around to get pretty close to exactly what I wanted to insure my truck wasn't getting overloaded.
    However, if indeed the figures come out like you've estimated.....yep, you'll be overloaded very quickly and I forsee a 3500 in your future.
    You are one of the very few new post people that have come on here with the knowledge that payload is the main factor when determining what size trailer you can pull. Very good!
    Most here, do recommend using 15% of the GVWR of the trailer as the figure to determine the tongue weight (usually called CYA), but I bet the majority of TT's never get to this high of a percentage.
    Ron
  • I don't think you will be anywhere near a 1400 lb hitch weight. Jayco says 700 lb dry hitch weight which is a light hitch weight for that size trailer. Probably looking at 1K tops so wait until you get loaded up for camping and take it to the scales with your family before buying a new truck.
