ruthiebaby88 wrote:
bighatnohorse - thank you for bringing my attention to the tire load ratings
Is that something that could be changed by buying different tires?
Do you find that the tire load rating is generally less than the vehicle payload - so you are erring on the side of caution using that number?
Yes. As a rule, stronger tires will allow one to exceed the manufacturers published payload rating.
As a rule, manufacturers install an axle with a large safety margin in terms of capacity.
For example, my trucks rear axle is rated by the manufacturer (Dana 80) for 11,000 pounds.
Dana sells it to Ford who installed it in my truck. Ford rates the rear axle for 9,100 pounds - BUT this trucks sticker tire load (payload) is 5,450 pounds - far less than the axle rating.
When I look at the tire's rating printed on it's sidewall, it is 2,910 pounds when used on a dually.
The dually has two tires (2,910 x 2) on each side, so that is 5,820 pounds per side.
And that 5,820 number is close to the payload rating that we saw (5,450 pounds) on the sticker rating.
If you're buying a used truck, it would be wise to learn if the owner has put factory rated tires on it, or if they upgraded the tires, or if they saved money and bought cheaper tires with a lower rating.
If you have not already figured it out - the axle rating is
(approximately) equal to the two supporting tire ratings combined.
If you're dealing with a used truck sales person, ignore most of what they say.
Instead, look at the tire's printed rating and look at the driver's side post sticker for the rear axle rating.
The rear axle rating and the tire's rating (tire's rating x2) should be near the same. The axle will probably be a little higher than the tire x2 rating.
Manufacturers tend to build in safety margins when they publish their ratings - which is why one sees the discrepancies between tire ratings and axle ratings.
But bottom line is the tire's ability to support the load.
