Bedlam
Mar 05, 2016Moderator
biofumes wrote:
It's always been my understanding , that a 3/4 ton vs a one ton truck does not have the same frame, the frame itself should be one of the biggest differences between the two.
The cummins forum has a lot of specs and specifics. I have the 4500, and no it does not have the same frame as a 3500, and all the suspension parts are rated for the payload and towing specs. Although, the engine is a 6.7 cummins, even the turbo is another size altogether. Hope that helps.
The same frame is now used between the 2500 and 3500 (there was one or two to years where the 2500 frame was lagging behind the 3500). Your 4500 frame is like my 5500.
BTW: Your Cumins only has 325 hp and 750 lb-ft in your chassis cab. The engine and transmission is identical to the 3500 but is tuned for longer duty cycle at full output with the chassis cab verses pickup.
