FishOnOne wrote:
Huntindog wrote:
I remember for some years the 450 pickup had smaller axles, and IIRC, the wide track front axle was an option, then I believe they made different GVWRs available. Some actually had LRE tires. Not sure if that is still the case.
The wide track front axle was always standard for the F450 and was an option for the F350.
The F450 ran 17" tires from '11-'14. All other years they ran the 19.5" tires.
The F450 has a larger rear axle, larger brakes, heavier front suspension components, and a different rear spring pack than a F350.
The F450 is simply a beast...
Do they have the same front axle?
