Bocifus
Jul 28, 2016Explorer
PD 4655 LED
I just installed a PD4655 this evening. Install was very straight forward. Installed a new battery as well. The problem is the wizard green led light does not illuminate. I've held the wizard butto...
Bocifus wrote:
As per PD tech service testing, I am to remove the two reverse polarity fuses and measure the converter input and the output to the battery.
Something is definitely wrong. The converter input is 18.65 volts. The output to the battery is 16.75.
Voltage at the battery is 16.6.
I'm going to borrow my neighbor's high priced voltage meter tomorrow, my cheap meters cannot be correct. I've two low priced meters that measured basically identical numbers.
Still no LED, I'll check the harness continuity tomorrow as well.
Could be a faulty board?
Stay tuned.
