Bocifus
Jul 28, 2016Explorer
PD 4655 LED
I just installed a PD4655 this evening. Install was very straight forward. Installed a new battery as well. The problem is the wizard green led light does not illuminate. I've held the wizard butto...
westend wrote:
If you removed the two fuses and then measured, you should see 0 V at the output to the battery. If the battery is at rest for a short period of time and the surface charge is removed, a fully charged battery should measure 12.6 V.
The input voltage to the converter, as mentioned, should be at utility voltage level or with a generator, in the neighborhood of 120 VAC.
Something is amiss with meter or measurement technique.
